DISCUSSION
Engine + Driveline
URGENT: Where is the oil pressure check valve?
Topic: URGENT: Where is the oil pressure check valve? (Read 3472 times)
arcter
June 06, 2010, 01:10:39 PM »
A DIY posted here for the e36 m42 mentioned an "oil pressure check valve" under a rubber gasket and in a hole on the block. This is for a head gasket job. My car is an e30 and we see no such rubber gasket or valve. Can anyone help? Urgent!
Last Edit: June 06, 2010, 03:07:14 PM by arcter
1991 E30 M42
Hero Member
Where is the oil pressure relief valve?
June 06, 2010, 10:21:57 PM »
it is mounted in the oil pump housing/timing case
1991 E30 M42
Hero Member
June 06, 2010, 10:23:26 PM »
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0504&hg=11&fg=30
#5-8
arcter
June 06, 2010, 11:09:10 PM »
Hey sorry I meant oil pressure 'check valve'. Turned out the e30s don't have them. Spent an hour trying to find it for nothing!
1991 E30 M42
Hero Member
June 07, 2010, 09:53:13 PM »
i must have misread it, it was late
romkasponka
Hero Member
-Receive: 3
Reply #5 on:
June 08, 2010, 04:28:31 AM »
Oil filter housing.
E30 318is M42
E36 318is M44
DISCUSSION
Engine + Driveline
