Author Topic: M42 Lower exhaust manifold flange- studs or what?  (Read 3661 times)
jimc2
« on: May 30, 2010, 05:00:23 PM »
Anybody know if the M42 lower exhaust manifold studs are threaded into the manifold flange or a headed press fit bolt? I see different pictures on parts suppliers and oem type diagrams.
Nice to know before I light up the torch and get the BFH out..
Thanks
Jim
jimc2
manifold threaded?
« Reply #1 on: May 30, 2010, 08:04:38 PM »
clarification:
post refers to item #2, does it thread or press into the manifold flange?
Thanks
colin86325
« Reply #2 on: May 31, 2010, 05:35:50 PM »
I'm pretty sure they are of the press-fit type.  They are easily replaced with high-quality metric bolts.
BlueBMW
« Reply #3 on: May 31, 2010, 07:33:55 PM »
Last ones I saw were on a 95 318ti with an M42.  The oem studs were strange.  They were not press fit but rather had a round head with a side cut off at an angle.  They looked like they were intended to be welded on.  I just used some nuts and bolts instead.
DesertEagle
« Reply #4 on: June 07, 2010, 07:01:41 PM »
On my 1991 318is, those "bolts" were tack welded onto the flange.  I used a dremel with the gyros cut-off wheels (i think 1.5").  The gyros wheels work so much better than the standard stuff.  I then replaced them with grade 8 bolts with lock washers.
Slick92GS-R
« Reply #5 on: June 16, 2010, 08:29:09 PM »
Quote from: deserteagle;93344
on my 1991 318is, those "bolts" were tack welded onto the flange.  I used a dremel with the gyros cut-off wheels (i think 1.5").  The gyros wheels work so much better than the standard stuff.  I then replaced them with grade 8 bolts with lock washers.
^^^ this !!!
