my driveshaft is rubbing on something. It's pretty loud as it's louder than the engine. It seemed to be coming from the shifter area so i had a look under the car.
My findings:
- the back-up switch wire was rubbing and partially cut. fixed and tied back in place.
- my shift linkage is worn
- tranny is leaking
- traces of rubbing on the guibo
- clearance between the linkage and the guibo is pretty small... normal?
so my question is: what's rubbing??? could it be the linkage (no shifting problems, it's sloppy and somewhat notchy, but still very very drivable)
or is it the CSB that's beat?
if it's the linkage, how could it happen???
thanks!:confuse
