So are you saying my tires are worn out? I do not understand what you are trying to say.
i'm saying if you have to threshold-brake, then your tires are not sticky enough, not wide enough, or both.
if you're still running 195/65-14s on bottlecaps or 14" basketweaves, then it's probably both.
i have had a lot of good results running all-seasons in a 225 section width. the KDWs have a treadwear rating of 300, and are technically an "all-season" tire. i've also had good luck with falken ze-512 in 225/50-15.
look at the stock wheels and tires and it's easy to see that there is room for more under the stock fenders.
if you drive your car as aggressively as your first post in this thread implies, then you NEED more tire than BMW saw fit to equip at the factory.
i went insane with spending money on my car while i was in iraq, and that's how i wound up with the setup i have. if i were trying to do it on a tighter budget, it'd look like this:
-good pads on new rotors
-16x8 et15 sportmaxx wheels
-225/45-16 falken ze-512
and honestly i'd probably be just as happy with it, 95% of the time.
