Author Topic: What should I do about my spoiler?  (Read 2900 times)
gravyface
« on: May 14, 2010, 06:14:17 PM »
I'm thinking here's my options:
1. Try to use some sort of adhesive and bond it to the trunk; scrape/sand and rattlecan (cheap, quick, might look like shit).
2. Pull it off, try to straighten it, scrape/sand and rattlecan (cheap, not so quick, might make it worse).
3. Finally buy a new spoiler, have it primed/painted in a booth by someone else (not cheap, best results).
Ummm how do you upload images?  I've linked to tinypic.com with the [ IMG ] tag; not showing up.
Here's the links:
http://tinypic.com/r/18evmb/5
http://tinypic.com/r/24crzfn/5
http://tinypic.com/r/142d8wg/5
« Last Edit: May 14, 2010, 06:34:37 PM by gravyface »
SpecFC
« Reply #1 on: May 14, 2010, 10:52:42 PM »
Id try a heat gun and some clamps first.
gravyface
« Reply #2 on: May 14, 2010, 11:08:22 PM »
Apply some heat to the curled up side and clamp it down?  The spoiler material is some sort of dense foam, not sure how well it'll handle the heat.
