Author Topic: noisy lifter+rocker after install dbilas itb+cam  (Read 2890 times)
yoyon
« on: May 13, 2010, 09:39:20 AM »
hello,
my engine is m42b18 e30 standard. recently i'm installing new dbilas ITB and camshaft+ valve spring.
once finish all item installed, the engine noise rattling from rocker+lifter is so loud.
i wonder, is it HVA failure? should i use solid lifter?
any suggestion is appreciated
thanks®ards,
flyinglizard
« Reply #1 on: May 13, 2010, 09:00:39 PM »
Run it at 1700- 1800 for at least five minutes. It goes away
 20 years of renting race cars
BlueBMW
« Reply #2 on: May 13, 2010, 09:32:50 PM »
Probably bad ITBs... you should just give them to me for free!  J/K yeah, they're hydraulic lifters and need to bleed out so you'll have some bad rattle for a few minutes.
carlos318is
« Reply #3 on: May 14, 2010, 04:52:56 PM »
I have had the same problem for years and never caused any damage
jmsra
« Reply #4 on: May 24, 2010, 10:31:30 PM »
So if i just replaced a cracked head and checked all the timing components and put it all back together i would get that diesel noise until the lifters were bled out?
yoyon
« Reply #5 on: September 04, 2010, 08:54:34 PM »
found out that hvas are bad condition, replace them with custom solid lifter
