Author Topic: e36 M42 head gasket replacement  (Read 4462 times)
bmwconnect
« on: May 11, 2010, 10:24:30 AM »
Hello, Doing my HG today but I'm stuck on the chain tensioner. I removed the 19mm nut but the pressure still seems to be on the chain and I'm not sure what might be wrong.
Also I broke the steel profile gasket around the thermostat housing. I want to avoid removing the lower half chain case, has anyone successfully RVT'ed that section ?
thanks in advance
Regards|
Bear
Midnight YouTube Channel
bmwconnect
« Reply #1 on: May 11, 2010, 01:13:12 PM »
sorted the tensioner problem.
BlueBMW
« Reply #2 on: May 11, 2010, 06:54:35 PM »
Does this mean that all that crazy turbocharging finally made it blow?
bmwconnect
« Reply #3 on: May 11, 2010, 07:12:59 PM »
Quote from: BlueBMW;92280
Ya I had a unfortunate mishap on the highway. pressure line to the turbo actuator slipped off and boost pressures sky rocketed and it was over quickly.
BlueBMW
« Reply #4 on: May 11, 2010, 08:28:16 PM »
How high did it go? :D
bmwconnect
« Reply #5 on: May 11, 2010, 09:03:34 PM »
I saw 21 psi and it was over. one of the spark plugs cracked also from the intense heat
BlueBMW
« Reply #6 on: May 11, 2010, 09:12:16 PM »
Crazy awesome!  Are you staying stock on the headgasket etc or are you going to something more suited for turbocharging?
