Author Topic: charging problem  (Read 2620 times)
bih55
charging problem
« on: May 07, 2010, 04:43:04 AM »
just noticed on my 93 318is it isnt putting out enough voltage. when the car is off it shows 12.6 but after I start it, it only shows 13.10 and max I noticed 13.30. even sometimes when the engine is running it would go under 13 volts. I took the alt already 2 times and had it checked at an auto parts store, shows up as good. checked the belt, good also. at night the cluster lights are dimmed also:confused:
locknload
charging problem
« Reply #1 on: May 07, 2010, 08:54:05 PM »
Bad battery?
Bad battery connections?
Bad battery ground?
Bad battery cables?
snitzer
charging problem
« Reply #2 on: June 06, 2010, 08:10:09 PM »
had the same issue with mine ..... brushes were shot ....20 dollar part .... (it tested good at the auto parts store too)
