Removing the thermo-viscous fan
Author Topic: Removing the thermo-viscous fan  (Read 6161 times)
Zoso
« on: September 01, 2006, 01:43:43 PM »
I know this is somewhat basic, but I had a bitch of a time trying to remove mine when I replaced my thermostat a year or so back.
I have a few questions on how to get the fan off.
What tool do most people use to grab the nut? All I had that fit was a large monkey wrench and it ended up bending and breaking some of the cooling fins on the fan.  I ended up giving up on removing the fan and twisted the thermostat housing through the fan blades.  It wasn't optimal.
Also, it seemed that the crank would just turn with the fan.  I couldn't seem to get a nice impact on it.  Looking back, maybe I should have put the car in gear?
(BTW, I know it is reverse threaded.)
aaron_silva
« Reply #1 on: September 01, 2006, 02:01:50 PM »
Your fan shouldnt be attached to the crank nut.  It is attached to the water pump.  Therefore, putting the car in gear wont stop it from turning.
I used channel locks to remove my fan.  To hold the pulley still I used a long screw driver wedged between the nuts.
Aaron
318iC
m42 fan
« Reply #2 on: September 01, 2006, 02:06:06 PM »
Here's the method I used to get mine off:
I took a long, thin screwdriver and wedged it between two of the bolt heads on the clutch.  This was to hold it still.  Next, I put a crescent wrench on the nut.  I used a hammer to give the wrench several quick raps while holding the fan from turning with the screwdriver.  I was able to break it loose after five or ten taps.
Hopefully that method works for you
Brian
aaron_silva
« Reply #3 on: September 01, 2006, 02:07:21 PM »
Also, this would be a good place to recommend replacing the water pump if it is original.  The original impeller was made from plastic and it is not fun replacing it when it explodes.  Hell, even the metal flange on that bolts to the timing case broke off when I started removing it.
Aaron
318iC
Same here.
« Reply #4 on: September 01, 2006, 03:01:57 PM »
Quote from: m42 fan
Brian
Same here. I call it (the hammer) a shadetree impact wrench!
Zoso
« Reply #5 on: September 01, 2006, 04:28:09 PM »
Thanks guys!
Does anyone know what size wrench I'll need?
Shadetree impact wrench.  rofl!  :)
« Reply #6 on: September 01, 2006, 05:11:18 PM »
Quote from: aaron_silva
Aaron
woah wait, thats a serpentine belt setup there..and you have an e30. Did you swap in a newer motor?
Deutschbag
« Reply #7 on: September 01, 2006, 07:12:02 PM »
Oooh serpentine belt.... do tell what's going on there, I've been looking into a serp setup since I bought my car.
aaron_silva
« Reply #8 on: September 01, 2006, 07:56:58 PM »
Oops sorry, I stole a pic from an M50.  They have a similar water pump setup.
I do however have this sitting in the garage:
:D
Aaron
318iC
« Reply #9 on: September 02, 2006, 01:30:04 AM »
harbor freight engine stand ftw!
Zoso
« Reply #10 on: September 02, 2006, 03:32:13 PM »
Quote from: dude8383
What a coincidence!  I was just looking through their catalog while taking a dump!  Small world!  :D
« Reply #11 on: September 03, 2006, 02:09:09 AM »
Quote from: Zoso
haha yeh man, great john material.
anyways its a good stand for the money. i bought the 750lb version.
sheepdog
  • Site Admin
« Reply #12 on: September 04, 2006, 02:14:34 PM »
When I did mine recently, I removed the fan blades, then went at the nut. I used a peice of angle iron drilled to match the bolt pattern to hold it in place.
« Reply #13 on: September 04, 2006, 02:36:16 PM »
I replaced mine w/ the factory pump.  The aftermarket ones w/ metal blades don't always fit exactly right and they are heavier than the plastic one.  The newer factory replacements have been improved.  They no longer will self destruct lol.  It helps to reduce the weight of the blades so that it is easier to turn, rev, etc.  NEW PLASTIC ONES FTW!!
M42boy
« Reply #14 on: September 05, 2006, 09:23:13 AM »
Looks like a freshly rebuilt M50 at that!  Who did the rebuild??
What do you plan to do with it??
