Author Topic: 318is Can't get AC belt on  (Read 3624 times)
Sarstan
« on: May 01, 2010, 10:54:11 PM »
I can't for the life of me figure out how to loosen the pulley for the ac belt.  I've got a bolt that screws on, but don't seem to connect to anything other than a chunk of metal inside a nearly impossible to see compartment, to which I think connects to the pulley.
I've tried removing the screw, lightly hammering at the pulley to push it, hammering lightly at the screw while in, and using a screwdriver to wedge between the metal object inside and the mount, all of which result in nothing.  Am I missing something here?
RED IS 91
« Reply #1 on: May 02, 2010, 05:23:06 AM »
You have to pop the plastic cover off the pulley and in behind it there is a bolt that holds the pulley on . Loosen that and you should be able to adjust it.
« Last Edit: May 02, 2010, 05:26:46 AM by RED IS 91 »
Wizard
« Reply #2 on: May 02, 2010, 07:52:01 AM »
Sarstan
« Reply #3 on: May 02, 2010, 11:54:12 AM »
Holy wow, I would have never thought that was a little cover!  Thanks a ton guys.  I've driven without AC in over 100F weather and I really missed it.
Sarstan
« Reply #4 on: May 02, 2010, 02:43:34 PM »
Alright, got it hooked up.  Again thanks a lot guys.  Can I ask what manual you're using to get the exploded diagrams?  My Haynes manual doesn't even mention doing anything but checking the AC belt, much less changing it.
seeohngee
« Reply #5 on: May 21, 2010, 11:28:00 PM »
That diagram is from realoem.com. You should check it out if you haven't, highly recommended.
