Author Topic: m42 into 325i Facelift  (Read 4896 times)
JungleGus
« on: August 31, 2006, 01:22:29 AM »
anyone done it? going to do it sometime next week if all my bits arrive....a mate bet me $100 i cant do it in 24 hours..we will see. the only thing im worried about it the wiring...hopefully its the same?
BrandC
« Reply #1 on: August 31, 2006, 03:49:48 AM »
Unless you have a parts car and the best luck in the world with rust, then I wouldn't count on the swap taking less than 24 hours.
Berlin
« Reply #2 on: August 31, 2006, 04:33:43 AM »
how is this a face lift, you mean an engine swap :s or are you putting diving boards and an is airdam on lol
JungleGus
« Reply #3 on: August 31, 2006, 07:36:07 AM »
what i need a parts car for? and rust? huh?
i wrecked a 318iS a wee while back....still not sure what i want to do with the engine, so i want to give it a go in my car. see what it feels like.
my main concern is wiring looms matching, so any help or thoughts concerning that would be great
and about facelifts, iS's are all facelifts, my car is a facelift 325..do they share the same car loom? 318 vs 325
and i dont imagine it will take 24 hours, but it will be fun to try :D
« Reply #4 on: August 31, 2006, 02:32:39 PM »
The wiring looms from the M20 is very different than that for the M42.  Different sensors, different ignition components, different injector booms.  IIRC from when i wrecked & stripped a 318iS, you have to chop the engine harness from the fuse box...and the wires differ between the M42 & M20.  Swapping fuse boxes means swapping every wire in the whole car.  The engine part could be done in a day probably.  The electrical part, you are lookin at a week minimum to do it RIGHT.  I think you owe somene $100 lol.
JungleGus
« Reply #5 on: September 01, 2006, 02:18:19 AM »
the car loom, not the engine loom, is different??
bugger...what about the 318i car loom? have one of those i might look at putting it into.
else i could figure out some sort of adaptor to plug straight into the 325i car loom big plug...all i would need to do is get the wires themselves sorted and what they did, on the m42 as opposed to the ones going into the m20 car.
hmm
not giving up yet...never said when the 24 hours had to start!
Febi Guibo
  • m42 reporter
« Reply #6 on: September 01, 2006, 10:57:09 AM »
kidneyboy on here has done the swap....
« Last Edit: September 01, 2006, 10:59:19 AM by Febi Guibo »
Support M42club.com !!
JungleGus
« Reply #7 on: September 02, 2006, 04:04:13 AM »
brilliant...need to talk to him
been comparing the car loom harness connector thing...( i know thats probably not its real name) the only difference is the 325i having an extra two wires, blue with thin black, and green and purple. sounds about right the 325i has OBC, the iS didnt....and im sure there is something else.
JungleGus
« Reply #8 on: September 02, 2006, 08:10:25 AM »
i need to have a better look (ie in the daytime) but the 325i has an extra blue and black (which i THINK is oil level) and a purple and brown (which according to m50 stuff is fuel relay)
another explanation is that one is the oil level, and one the OBC speedo signal
hmm...might give it a go and see where i end up!
just musing out loud here..will try get someone to take pics...should be fun
« Last Edit: September 02, 2006, 08:14:04 AM by JungleGus »
