i have a question again..
I just bought a diff from pull a part, it came off a 93 325i same exact diff case, even asked the ladie she said it was interchangeable. so i go out there take the Diff off the 325i. So i get back and take my old diff off and put the 325i on my 318is, everything fit well, nothing went wrong.
until i drove it and it has a lower gear ratio, it seems. at 65mph Im buried at 4rpm. with the old one i was close to 3rpm at 65mph.
What i dont get is the engine in the 325i was the same engine as mine,
same engine block, same intake, the only thing i seen that was differnt was the fuel injectors which i took, want to know if the fuel injectors for the 325i will work with my car.
but the biggest thing i want to know is why there is such a big difference in rpms, i thought the guy that use to own the 325i had some 17inch rims or somthing. is there a difference if the car was automatic or Manuel?
ha if i did go and buy some bigger wheels would this lower the rpms?
Also is 65 at 4rpms bad for my engine, i dont want to blow my motor
thanks for your help
