Author Topic: fuel hose to filter leaking  (Read 2348 times)
fayjai
« on: April 13, 2010, 07:45:25 PM »
Appears that the fuel hose connecting down to the fuel filter is leaking, changing it would be tough as I would most likely will have to remove the gas tank to access this line.
Do you think its possible to use some hose tape as a solution for time being?
Thanks.
Romrog318is
« Reply #1 on: April 13, 2010, 08:52:55 PM »
no
someone tried that with hose clamps on mine and it still leaks
if you want an easy less complicated way to do it just get a piece of metal fuel line and cut your hose where its leaking and put that in the hose then clamp it together good...
best way is to replace the whole thing though
no more M42
fayjai
« Reply #2 on: April 13, 2010, 10:35:28 PM »
thanks romrog, I was thinking of that as well as it appears replacing that hose in particular will require some small hands...
Romrog318is
« Reply #3 on: April 14, 2010, 08:34:00 AM »
nahh you can get it from under the seat if i remember right lol
no more M42
