Hi All,
Need a little assistance here. I've seen tons of thread so far on this and there do not seem to be any with a solid conclusion.
I have a '96 E36 328i coupe (no A/C) and it's overheating. I suspected a leaking rad for a while and this resulted in it failing (blowing the exp. tank). I changed the T/S and added a new rad and this proved to work fine, apart from it being a PITA to bleed.
On start-up the engine temp slowly rises to mid way on the temp gauge and stays there, T/C clicks open, flow circulates, fan is working, engine stays at mid-temp. However, after about 20mins there is still no heat from the matrix in the cab and the coolant starts to boil up and splutter then the engine temp starts to rise to the point where I have to cut it and start again.
I’ve taken the pump off and it’s fine. It looks brand new, I imagine the prev. owner had it replaced knowing of an issue… At the mo, I suspect it’s the Heater Control Valve, it clicks to hot but is sticky and perhaps it’s clicking back to cold when I fill/bleed the system causing an air pocket? The new part is here so I’ll install it tonight and post how it goes.
I just hope it’s not the head gasket. Anyone had the same issue and solved it? Also, anyone have any solid tips on a thorough system bleed?
Cheers,
M
