318i M42 conversion
Author Topic: 318i M42 conversion  (Read 10830 times)
Cre8toR
    • http://www.teamBANG.com.au
318i M42 conversion
« on: April 11, 2010, 08:20:18 PM »
Hey guys, I have a 4 door 318i with a crapy single cam motor, Its starting to die and i a have ecu harness everything from a 318is i stripped out a while back but the motor was stuffed. My question is how hard is to just drop the M42 motor in.. It seems like an easy conversion to me? Mounts ect look the same so is it just change the loom and ecu + manifold and thats it? Also if someone has a M42 motor around the area of sydney that you want to sell im very interested. I have quotes of $600, if you can beat that sweet!
Thanks guys
  • -Receive: 5
318i M42 conversion
« Reply #1 on: April 11, 2010, 09:11:21 PM »
As far as I know, the M40 (8 valve) and M42 share the same block so the engine mounts etc should be identical. I expect everything would bolt right in. Thankfully BMW in the US decided to sell the poverty spec 318i with the M42. No swap required.
good luck
Justin
BlueBMW
318i M42 conversion
« Reply #2 on: April 11, 2010, 09:46:05 PM »
Are you swapping out an M10 or M40?
Cre8toR
318i M42 conversion
« Reply #3 on: April 12, 2010, 02:17:37 AM »
Im swapping the stock 1.8L 8v single cam motor for the twin cam 1.8L Twin Cam.
I have swapped motors ect before so im pretty switch on with it, But just want a heads up in case the mounts ect are different in some way or not you know?
Is there much in swapping the loom? It just plugs straight in right?
douby
    • http://www.doubrava.net
318i M42 conversion
« Reply #4 on: April 12, 2010, 06:25:33 AM »
Quote from: Cre8toR;90741
so are you swapping out an  M10 or M40? There were 2 1.8 8v engines.
This is an M10B18:
and here you see M40B18:
\'92 318iS Touring ///M-technic II
\'96 Seat Toledo 1.9D Winterwagen
\'98 Fiat Fiorino 1.7td
\'03 Škoda Octavia 1.9TDI
dinu.negrean
318i M42 conversion
« Reply #5 on: April 12, 2010, 04:58:50 PM »
If it is an M40 we are talking about it is pretty straight forward. If you have doubts on any of the parts, go check realoem.com
If you want another opinion I can check with tecdoc, just pm me.
M42 covered in Kaschmirbeige Metallic
Cre8toR
318i M42 conversion
« Reply #6 on: April 12, 2010, 06:52:23 PM »
^^ Thats my beast lol..M40? its in a 97 E36. The loom ecu etc etc i have is from a 98 e36 318is so will that still mate up with a M42 motor say from 91? Cause im sure there is two series isnt there?? I am pretty sure its a straight forward swap, Just wanted to make sure you know. Thanks for the help peeps i appreciate it =) Think ill be on here more now, Very helpful
Cre8toR
318i M42 conversion
« Reply #7 on: May 06, 2010, 11:14:33 PM »
Hi guys, I am picking up the new M42 motor tomorrow for the conversion from an M40. Just want to make sure all i need is the motor, ECU and loom for the conversion and everything else is the same.. The new loom will just plug straight into where the old one did?
Plug and play right?
opelmantagsi
318i M42 conversion
« Reply #8 on: May 03, 2011, 08:44:11 PM »
any update on how this went?
