Author Topic: Thermostat stuck?  (Read 2216 times)
fayjai
Thermostat stuck?
« on: April 09, 2010, 02:29:58 PM »
Just finish replacing all the hoses underneath the intake, now trying to bleed the system but no coolant seems to bypass the radiator hoses (remains cold).  I am under the assumption that the radiator is stuck closed?  I may have reverse the coolant temp sensors connected to the block but even then, coolant should flow correct?
Any help greatly appreciated, need the vehicle running asap.
Phreon
Thermostat stuck?
« Reply #1 on: April 11, 2010, 03:40:00 PM »
Are you overheating?
You can test the thermostat by dropping it in a pot of water on your stove. It should open just before boiling.
P
