How to remove engine with a hoist?
Author Topic: How to remove engine with a hoist?  (Read 2475 times)
blalor
« on: April 09, 2010, 11:06:25 AM »
Morning, all.  I'm going to start working on swapping a new M42 into my 318is tonight (the intake valves on mine bent due to that bad deflector wheel).  I bought a hoist and load leveler from Harbor Freight last weekend.  The engine currently in my car has the head removed.
Three questions:
1. do I need to put the head back on in order to remove the engine from the car without the transmission?  If not, what do I bolt the chain to, and with what size bolts?
2. the "new" engine is currently hanging from my hoist – sans transmission – with a bit of discarded seat belt (don't ask). It has a head. I see the big loop on the front of the engine, but there are several holes to choose from on the back of the engine. Again, where do I attach the chain for the load leveler?
3. (more out of curiosity) when removing the engine and transmission together, where do you attach the chains?
If it's not obvious, I haven't done this before. :) The Bentley manual just says to "remove the engine". :confused: I searched and didn't find a howto (maybe it's too obvious), but I'll write this up when I'm done.
P. Kennedy
Me 2
« Reply #1 on: April 09, 2010, 11:24:22 AM »
I'm about ready to pull an M42 also, this being my maiden voyage into this type of procedure.  Hope to see some responses and guidance from those that have done this.
monko141
« Reply #2 on: April 09, 2010, 01:11:32 PM »
1. Without the head on you can take the water pump out and create a loop through the timing chain case.
2. There is a loop on the back of the of the block that you attach the chain to.
3. Same loops on the back of the block and the front of the head.
