Author Topic: Getrag 240 manual transmission  (Read 7018 times)
thebutcher37
« on: March 23, 2010, 03:45:44 PM »
Has anyone had any experience rebuilding, or even just opening up the 240 transmission im taking manual transmission and driveaxles in school and I have my beat up transmission that i want to take a part and work on..
Ive started taking it apart and ran into a problem removing the output flange lock plate and collar nut. Ive used On Demand 5 at school and it says we need special tools..(23 1 200, 23 0 020, and 23 1 210) and (33 1 150)
what tools are these, and where can i get them....
the picture shows what nut i cant remove because i dont have a socket thats thin and long enough...
Its in the middle of the pic, between the triangular thing that hooks to the drive shaft (sorry for my lack of vocabulary)
« Last Edit: March 23, 2010, 03:51:07 PM by thebutcher37 »
jou ma se poes in \'n fishpaste jar.
thebutcher37
I think im on to something...
« Reply #1 on: March 24, 2010, 12:48:35 AM »
http://www.esatclear.ie/~bpurcell/318ismaintenance.html#gbros
Check that link out it talks about how to modify a socket to fit the nut.
The rest is copied from the site:
Before even dreaming of starting the gearbox seal job, the correct socket for removing the output flange nut must be sourced or made. The following are the important dimensions:
30mm hex
Outside diameter = 39.0mm +/-0.5
Internal length = 70mm at a minimum diameter of 15.5mm
I used a 1/2" drive 30mm impact socket and turned it with a lathe. I then had to drill out the end to make it long enough. The pics should explain it:
and this is what it looks like taken apart.
