DISCUSSION
Suspension
Z3 suspension?
Topic: Z3 suspension? (Read 3904 times)
318isle
Z3 suspension?
March 12, 2006, 09:59:42 PM »
Does anyone know if the Z3 suspension will bolt up to our cars?
Will there need to be any fabrication for the mounting points?
TIA
fabe
Z3 suspension?
March 13, 2006, 11:52:57 PM »
The rear subframe is bolt right on.
u can use the front absober struts as well but u to add caster to push to wheels forward and also camber plates to increase -ve camber.
Administrator
Legendary
-Receive: 33
Z3 suspension?
March 14, 2006, 12:35:53 AM »
Is there an advantage to swapping for a Z3 rear? Well, other than getting 5-lug hubs if you swap trailing arms.
Visit
HERE
for a plethora of 318iS stuff and some other randomness. Would you say I have a,
plethora
, of pinatas?
DISCUSSION
Suspension
Z3 suspension?
