Author Topic: Idle issue after top end rebuild  (Read 1964 times)
rennen
« on: February 23, 2010, 08:07:48 PM »
Hey guys,
So I recently rebuilt the top end on my 91 318is. New head gasket, all intake and exhaust gaskets, water pump, timing chain, m44 timing tensioner, timing chain guides, valve cover gaskets, all front timing cover gaskets,  thermostat, throttle body heater plate delete and all new vacuum hoses. I still have a weird idle issue.
So from stone cold, I start the car and give a little throttle. If I let off of the accelerator, it will bog and die.
So,
I give here a little more throttle to keep it alive. And it does unless I let off the throttle.
So,
I drive the car and if I come to a stop and let off the throttle it dies again.
So,
It warms up a bit and the bog seems to become more stable. It won't die at all. Its strong as nails.
Where should I start?
BlackBMWs
« Reply #1 on: February 23, 2010, 11:13:34 PM »
Check the ICV and it's connections.     :cool:
BMWCCA# 160411
