Author Topic: Vacuum tests  (Read 3677 times)
electrofelix
Vacuum tests
« on: February 19, 2010, 07:35:13 PM »
I thought that the bentley manual would have some details on what measurements you should get when testing the various vacuum lines on the car, but I can't seem to find any.
Anyone know what values I should be seeing, plan to test all the various lines tomorrow, so it would be useful to know what the specifications should be.
"Nothing is foolproof to a sufficiently talented fool" - unknown
\'93 318is Coupe Manual (Euro) RHD
fiftytakedowns
Vacuum tests
« Reply #1 on: May 25, 2010, 12:36:53 AM »
bump?
Hybrid775
Vacuum tests
« Reply #2 on: May 27, 2010, 10:08:18 PM »
Testing vacuum? I would just visually inspect the hose and replace the broken ones necessary.
DesertEagle
Vacuum tests
« Reply #3 on: June 07, 2010, 06:56:05 PM »
The manual that came with my mightyvac hand vacuum pump went into a lot of detail on how to interpret vacuum readings/fluctuations.  I also found info in the Bentley e36
fiftytakedowns
Vacuum tests
« Reply #4 on: February 10, 2011, 02:44:35 AM »
Quote from: DesertEagle;93343
care to explain?
