Author Topic: valve cover bolts loose  (Read 2277 times)
318lotis
« on: February 19, 2010, 12:19:35 PM »
ive noticed that there are two bolts loose or striped on valve cover, would anyone know a good quick fix these? two bolt are are just siiting in position and loose will not tighten.
dinu.negrean
« Reply #1 on: February 19, 2010, 12:26:42 PM »
If you want a good fix, there is a kit for reparing it, just look for it, plenty of movies on youtube.
If you are looking for a cheap and quick fix I can tell you what I have tried, and it Worked great. I had my visit card box, in thin aluminium.. what the light bulb turned on. I have cut pieces o 1.5-2cc height and 0.5-0.7cm wide, put it against the bolt and curbed it on the bolt. It looked smth like this:
 _________
(_________(
 Droped in the hole an tighten the bold inside. Worked great, it would not leak anymore.
romeomike
« Reply #2 on: February 23, 2010, 11:41:19 AM »
By God's kindness I found some on a salvage yard 318is and those fixed the loose one I had.
Adios for now,
RM
Choking Hazard
« Reply #3 on: February 23, 2010, 07:07:48 PM »
You don't want to overtighten those- they have a lip "to keep the O-ring from deforming" -said the book- that makes 'em a real easy FU.  :(   Like, guess how I learned this?
[SIGPIC][/SIGPIC]-Scott
///M3Mike
« Reply #4 on: February 25, 2010, 09:41:47 AM »
Heli-coils.  I ended up doing 6 on mine. 4 were one and 2 were close.  Someone went to TOWN on that thing before I owned it.
