Author Topic: m42& m44 heads  (Read 5394 times)
dletica
m42& m44 heads
« on: February 18, 2010, 04:50:06 PM »
hi,Can any one tell me if a m44 head will fit on a m42 block?
Letsplayskatch
m42& m44 heads
« Reply #1 on: February 19, 2010, 04:04:21 PM »
Yep
rob_e30
m42& m44 heads
« Reply #2 on: May 27, 2010, 04:54:09 PM »
Any more details?  Is it plug and play?  Do all the timing components from the M42 work or do you need to use M44 gears?
Any first hand experience is appreciated.
BlueBMW
m42& m44 heads
« Reply #3 on: May 27, 2010, 05:34:54 PM »
When I last worked with an m44 head it seemed that the threaded holes for the two temp sensors were different.  It seemed like the later ones used a single 4 pin sensor instead of the two separate sensors. I could be mistaken.
Sean_318is
m42& m44 heads
« Reply #4 on: May 28, 2010, 05:24:20 AM »
What is the advantage of this swap? Lighter drive train? More power?
Just curious.
1994 BMW 318is Coupe
Cristian G in Oz
Plug and Play it is but....
« Reply #5 on: May 28, 2010, 05:46:30 AM »
Quote from: rob_e30;92974
I put an M44 head on an E30 M42 block.
There are a few things to remember.
They are interchangeable, but as indicated the series 2 M42 heads and M44 heads used a 4 wire single sensor for temp.  This does not work with the E30 gauge cluster.
The timing components are the same and interchangeable, but if you use M44 timing covers the cam positon sensors are in different places.  You may need to "reset" the cam position so that the computer still gets the right signals.
If your using a series 1 inlet (E30) with the "log" manifold, you cant use the rockercover, it hits the inlet.  If you change over to the "curvy" series 2 or M44 manifolds, no problems.
Also the M44 rockercover has oil squirters in it to lub the roller rockers.  I changed all the gear into the early rockercover.
After a little work the M44 head will fit.
I've now done over 20,000 km since I did my head change and have had no problems with it or the top end of the engine except for not having an accurate temp sensor on the dash.
Cristian
1990 318is
