Author Topic: Lower control arm spacer kit??  (Read 3248 times)
flyinglizard
« on: February 17, 2010, 07:11:44 PM »
Is there a source for dropping the outer ball joint connection ? I want to lower my car further and retain some camber gain. TIA. MM
 20 years of renting race cars
1991 E30 M42
« Reply #1 on: February 17, 2010, 09:02:15 PM »
custom control arms or custom struts considering its a pressed in ball joint
flyinglizard
« Reply #2 on: February 18, 2010, 03:41:46 PM »
I am looking for  longer ball joint that wil press in without custom fab.  Iwant to lower the outer point, and/ or raise the inner about 1/2 in. .
 MM
dvmotorsports
« Reply #3 on: February 18, 2010, 03:55:38 PM »
So basically you want to find another ball joint that fits, but with different height dimensions?
flyinglizard
« Reply #4 on: February 18, 2010, 06:45:49 PM »
Yes. Coleman makes a few long ball stud joints.  Do you have any that have been pressed out??
     I use them for stockcars. Mostly GM and chrysler sizes.
 When the car gets  so low that the LCA point up, it is camber loss and roll center issues.
 The old style cars with the three bolt struts , could just be spaced between the strut and lower ball joint box.
dvmotorsports
« Reply #5 on: February 18, 2010, 08:04:49 PM »
I have none that have been pressed out. I do have some replacements in the trunk though. I don't even know why. I have E30M control arms, i don't think those can be pressed. I think the extras just came with  the car.
