Author Topic: adjustable FPR  (Read 5984 times)
1991 E30 M42
adjustable FPR
« Reply #15 on: February 18, 2010, 06:23:51 PM »
no it only goes inline on the return line, the supply line stays unmodified
4banger
adjustable FPR
« Reply #16 on: February 18, 2010, 06:30:31 PM »
got it.
:D:D[SIGPIC][/SIGPIC]
deekay
adjustable FPR
« Reply #17 on: February 18, 2010, 09:32:34 PM »
Quote from: 1991 E30 M42;87738
Remove the stock fpr then weld a plate onto the flange where it once attached, on mine I welded an 1/8"npt bung into it to mount the gauge off of. once the fuel rail is finished, run the supply hose to the rail then the return hose from the rail should go to the external fpr, then the outlet of the fpr goes back to the tank.
not knocking your setup at all, but the part i linked was plug-and-play. downside: it took a while to arrive from england. just for OP to consider.
4banger
adjustable FPR
« Reply #18 on: February 18, 2010, 09:51:45 PM »
i have a tig. its really no bother.  ive been contemplating cutting up a spare lower intake i have a building a custom short runner intake.
deekay
adjustable FPR
« Reply #19 on: February 18, 2010, 09:56:40 PM »
Quote from: 4banger;87791
rock on, then :)
4banger
adjustable FPR
« Reply #20 on: February 18, 2010, 10:09:59 PM »
funny thing i dont rember those injectors being such a bastard to get out when i cleaned and changed the Orings 7 years ago lol
deekay
adjustable FPR
« Reply #21 on: February 18, 2010, 10:41:59 PM »
i think that may be my favorite thing about the ITB setup. all i do now is get a rag to catch spillage and unbolt the fuel rail.
1991 E30 M42
adjustable FPR
« Reply #22 on: February 18, 2010, 11:22:31 PM »
Quote from: deekay;87788
any external fpr and be plug and play if you leave the stock fpr on the rail, but why would someone want to do that if they have a tig or access to one, whats the point of having 2 fpr's when only one is actually regulating the pressure
« Last Edit: February 18, 2010, 11:25:50 PM by 1991 E30 M42 »
4banger
adjustable FPR
« Reply #23 on: February 18, 2010, 11:43:26 PM »
the afpr still needs to draw a vaccum dosnt it?  how thick of aluminium stock did you use to cap off the stock fitting for your guage?
deekay
adjustable FPR
« Reply #24 on: February 19, 2010, 12:10:43 AM »
Quote from: 1991 E30 M42;87804
like i said once already... the one i got has a fitting that replaces the stock FPR. it's not a secondary. the only PITA with it is finding somewhere to mount it, but my friend and i fabbed up a bracket with some flat aluminum and a grinding wheel in about 10min.
to reiterate, i wasn't knocking your setup, just presenting the pros/cons of an alternative.
4banger
adjustable FPR
« Reply #25 on: February 20, 2010, 12:49:37 AM »
im gonna try to get to dads shop tomorow and machine that lip down where the gasket seats for the stock fpr and hopefully get the plug welded in and the fitting welded in if the speedshop in town has the fitting. rest of the shit is still on order and im waiting for the junkyard to unthaw to go pull some injectors.
4banger
adjustable FPR
« Reply #26 on: February 20, 2010, 07:22:47 PM »
i didnt like how it turned out. i think im gonna fab up a aluminium fuel rail. fuel rail stock isant that expensive.
