Thanks guys. Okay, I have two more things to ask about.
For months now, before this happened, I've had some rough cold start issues as well as a low-dipping idle. Any time the car is cold, basically, it starts rough and if I don't give it gas it'll fall really low, almost feeling like it'll stall. If I give it gas for a couple seconds, it's fine. The past couple days I've had it happen worse than before but it's basically the same. Mechanic said it's probably the fuel injectors?
The other thing is when I'm driving, and it seems to get in moods when it wants to do it. When I'm driving and I push in the clutch and let the revs fall to idle, it'll dip low and start to shake. Usually not very low but low enough to make it rumble a little. It'll then correct itself and idle fine. I've had this since before the timing chain problem too, and the mechanic has been pointed to it several times but all he's ever said is might have something to do with the throttle cable, and he's adjusted the idle a few times but to no avail. Any ideas?
Car seems to be running quite well other than these problems!
