Author Topic: m3 lifters  (Read 3188 times)
tigit
m3 lifters
« on: February 07, 2010, 12:17:22 AM »
I searched, but didnt find a sure answer. Can e36 m3 lifters be used on m42 motors?
Warsteiner
  • -Receive: 21
m3 lifters
« Reply #1 on: February 07, 2010, 06:56:52 AM »
If you're looking to just buy US E36 M3 lifters and drop them in...then the answer is no.  If you want to modify your valve train to lighten it using US E36 M3 parts...then the answer is yes.
tigit
m3 lifters
« Reply #2 on: February 07, 2010, 12:08:04 PM »
well what modifications are needed?
Warsteiner
  • -Receive: 21
m3 lifters
« Reply #3 on: February 07, 2010, 05:02:55 PM »
Different cam trays, different lifters, different springs, two areas on the cam tray need to be clearanced on the exhaust side, oil feed needs to be redone on exhaust side.  That's about it in a nutshell:-)
Ricer Ennemi
m3 lifters
« Reply #4 on: April 19, 2010, 12:29:12 AM »
I heard that S50 lifters are 37mm and not 35mm like M42.
What about the M44 solid lifters?Of any use?
nicknikolovski
m3 lifters
« Reply #5 on: April 19, 2010, 04:31:39 AM »
M44 uses hydraulic tappet and rocker arm set-up not lifters. Different cyl head on M44.
Warsteiner
  • -Receive: 21
m3 lifters
« Reply #6 on: April 19, 2010, 07:01:41 AM »
The US 3.0/3.2 are 33mm. The Euro 3.0L/3.2L are 37mm just like the E30M3 S14 which are definitely 37mm.
The M44 is completely different.
~Ralph
