Author Topic: holset turbo's  (Read 4221 times)
4banger
holset turbo's
« on: February 05, 2010, 04:55:49 AM »
anyone running a hx35 or a hx40 on a m42?
:D:D[SIGPIC][/SIGPIC]
kevins08
holset turbo's
« Reply #1 on: February 05, 2010, 01:50:39 PM »
kevin iz running an hy35 soon. :).....
hx40 will be pretty laggy. if you wanna drag your m42 go for, but id say if you want something to remain responsive on a roadcourse, etc. id go no bigger than hx35. and for low boost setups i would recomend neither.
dvmotorsports
holset turbo's
« Reply #2 on: February 05, 2010, 03:54:56 PM »
This guy has an HX40 hybrid
Absolutely Insane
There is a thread around here about it.
4banger
holset turbo's
« Reply #3 on: February 06, 2010, 12:29:02 AM »
ive got a hx35 off my truck from when i did a bunch of work and upgraded to a schwitzer s400.  the hx35 dosnt have a wastegate and has ugraded hot side prop. boost should come on about 3500 i figure. im thinking the hx35 maybe a bit big for the m10 im building so ive decided to turbo my 4door daily driver
kevins08
holset turbo's
« Reply #4 on: February 06, 2010, 03:23:24 AM »
should be about right... so youll be keeping it internally gated your saying? psi plans?
and i heard the guy with the hybrid is rebuilding due to throttle response/lag issues i believe...
4banger
holset turbo's
« Reply #5 on: February 06, 2010, 04:01:52 AM »
we never run wategates bov's or boost controlers on high performance diesel trucks.  i supose ill have to do a external gate and use a bov. gas turbo motors are all new to me but i have a fairly good understanding of the system.
ive had hx35's put out upwards of 40psi on a diesel. im shooting for 18-20lbs of boost on the m42. forged internals decompressed pistons. the whole deal.
Bunta
holset turbo's
« Reply #6 on: February 07, 2010, 10:27:54 AM »
What size is the hot side?
Im rebuilding a externally gated 12cm HX35 for my car
Split pulse manifold and 44mm tial WG, 50mm BOV
split pulse with the 4 banger is the key.
Use the pulses to your advantage.
Hunter
4banger
holset turbo's
« Reply #7 on: February 07, 2010, 03:00:59 PM »
i dont have it infront of me but as far as i rember intake side is 4in and hot side is 4.75xxxin.  antrim diesel up in PA did the work on the hx35.
kevins08
holset turbo's
« Reply #8 on: February 08, 2010, 10:25:45 PM »
hotside of the hx is 12cm and the hy is 9. hy is found on the automatics and hx on the manuals.
