Author Topic: want to trade my track car  (Read 3516 times)
Big Dog
« on: February 04, 2010, 09:02:20 PM »
I just don't have the time and/or money to take my track car out anymore and it deserves a good home with someone that can drive it like they stole it.  It's fun, fast and embarasses newer cars.  Particulars:
1979 528i, euro spec, no sunroof and fully modified for the track:
Modifications/Go fast goodies:
1991 M30b35 engine with complete wiring harness and ECU
AutoPower full cage (welded in) with high density padding
Zender rear spoiler
Frank Fahey front crank hub
Oil cooler with thermostat
Crank scraper with baffled oil pan
Mustang 22lb. injectors
MSD 6AL
Frank Conforti ECU chip (6900 rpm redline)
Bilstein shocks on custom coil overs with threaded collars
Corner balanced and competition alignment
Suspension Techniques front and rear oversized sway bars (rear is adjustable using heim joints)
Blanton dog leg close ratio 5 speed
Blanton M535i rear diff with 50% limited slip
Cold air intake and air box
475 lb. front springs, 275 rear
5 point cam lock harnesses
Aluminum seats
Autometer gauges (tach, oil pressure, oil temp, fuel pressure, voltage and water temp)
Sweet Engineering quick release steering wheel
Sparco aluminum shifter knob on Metric Mechanic short shifter kit
Lexan side windows and drivers side window net
Paint is 1997 Chevy truck bright red using DuPont ureathane
733i front rotors with M535i ATE calipers, rears are 633i rotors with ATE calipers
All synthetic fluids (oil, tranny, diff, brake and power steering)
Custom built 4 row radiator and flex cool electric fan
New guibo and rear CV joint boots
180 degree wide angle interior mirror
I/O Port camera mount with safety strap
Hawk blue pads (front) and HT 10 (rear)
Rotors have been cryo treated and heat treated (fronts are new)
Drilled lug bolts
Borbet 16X7.5 rims
Front brake ducting
Front tow strap
Front and rear tie down loops
BSR switch panel with industrial grade toggle switches
Battery in trunk with marine style battery box, ratchet tie down/aluminum tray
Want to trade for 3 or 5 series street car or enclosed trailer.  Car is near Charlotte, NC, cell phone is best way to reach me, 704-236-7308.
