Author Topic: m10, m42, m44 ITB's. Individual Throttle Body setup  (Read 9941 times)
Rich86
« on: February 03, 2010, 02:10:15 AM »
I am putting up for sale my Fuel injection setup.
It currently is setup with a sidedraft manifold for an m10 but the throttle bodies will also bolt up to any other dcoe sidedraft manifold such as the dbilas or any other m42/m44 dcoe sidedraft manifold.
I bought this stuff when I purchased my 1970 2002 with the hopes of going with a Megasquirt setup. Everything is in great used shape or with a few of the things (Throttle linkage and fuel filter) are brand new and have never been used. Everything I have is Manufactured by Weber unless otherwise stated.
I have:
- 2 Weber 40mm DOCE Type ITB's.
These come complete with Pico injectors, fuel rails, fuel pressure regulator, throttle position sensor, vacuum rail for map sensor, and throttle levers.
- A Warneford Designs DCOE type manifold which is made for the m10. The manifold is in great shape.
- A four post wasted spark ignition coil
- Fuel Filter
- Mount for an inline fuel pump
- A couple feet of Weber fuel line
- DCOE Type throttle cable linkage
- Air temp sensor by, Magneti Marelli
- Magnetic pickup by, Magneti Marelli
- ICV, Idle control valve
- 2 air horns for the throttle bodies. (you need two more)
This setup will scream on an m10 or m42/m44!
asking $1200 but am open to offers as well. Less than that if you don't want the m10 manifold. Located in Rohnert Park CA.
Let me know if you have any questions. Thanks for looking!
-Richard
« Last Edit: May 21, 2010, 04:59:05 PM by Rich86 »
Rich86
« Reply #1 on: February 08, 2010, 01:06:06 PM »
Bump.
Open to offers on this setup.
« Last Edit: May 21, 2010, 04:59:20 PM by Rich86 »
Rich86
« Reply #2 on: February 23, 2010, 05:34:18 PM »
Bump
« Reply #3 on: February 24, 2010, 09:47:22 PM »
Might want to mention your location in case someone local wants to pick it up.
I would also list this over on R3V.
Rich86
« Reply #4 on: March 18, 2010, 07:15:18 PM »
Quote from: dude8383;88359
Updated with location. Rohnert Park CA. Already on r3v too thanks!
Rich86
« Reply #5 on: May 21, 2010, 05:00:04 PM »
Bump. Price drop.
I know someone wants some ITBs
cncmastr
« Reply #6 on: May 26, 2010, 06:21:57 PM »
That looks really sweet! May I ask what benefit this has over a stock setup? Sorry for the noob question.
grant69
« Reply #7 on: May 27, 2010, 10:17:55 PM »
Hi Rich
 is this itb's setup still for sale?
