Author Topic: 318is blown gearbox will 318 z3 box fit  (Read 2914 times)
elijah
« on: January 30, 2010, 01:11:26 PM »
if not then do you know of any others:confused:
nicknikolovski
« Reply #1 on: January 31, 2010, 12:39:08 AM »
Z3 1.8/1.9 uses the same gearbox as the E36 318is (Getrag 250) but different shifter arm and shift lever mechanisms. I believe the Z3 uses a short shifter set-up.
elijah
« Reply #2 on: January 31, 2010, 07:48:03 AM »
its an e30 that i have but i think the engine is the same bar the inlet manifold can i use the z3 gearbox and shortshift set up on the e 30 thanks
nicknikolovski
« Reply #3 on: February 01, 2010, 02:25:35 AM »
I own an E36 but I believe you can put the Getrag 250 into an E30 so I would say yes.
elijah
ive got a new gearbox today but.....
« Reply #4 on: February 10, 2010, 01:23:41 PM »
on the bell housing side of the box there is a spline shaft and on the end there is a spiget to line up with a bearing the new one is bigger than my old one can u change the bearing inside the engine very easily
  • -Receive: 5
« Reply #5 on: February 10, 2010, 02:08:42 PM »
The gear ratios are totally different. You will have to swap your diff.
