Author Topic: speedo signal, what does it look like  (Read 2577 times)
doitover
« on: January 24, 2010, 05:36:42 AM »
Anyone know what the speedo signal from the rear axle speed sensor looks like?
Is it 0 to 12 Volts? Does it bounce on open and close?
Thanks, no access to an oscilloscope at the moment and haven't been able to find anything on it.
« Reply #1 on: January 24, 2010, 08:49:42 AM »
I found this site, seems to be a 0-8vdc signal:
http://www.unofficialbmw.com/e30/interior/e30_speedo_sender_problem.html
He noted some resistance readings as well, so I'm not sure.  You're right that there isn't a lot of info out there.
Why not jack up the rear of the car & spin the wheels slowly while having your DMM hooked up?  That'd give you a good reading...remember to post your results.
doitover
« Reply #2 on: January 24, 2010, 03:53:25 PM »
I think I came across the answer. Knowing that the sensor is a reed switch, it is pretty unlikely that it is bounce free. I came across a circuit intended just for that application, a magnetically controlled reed switch. Just a 555 timer in one shot mode. Having spent so long in digital design I tend to forget the useful analog solutions to things.
Testing it in the driveway is a good suggestion. A multimeter wouldn't tell me what I need to know but I could have hooked a counter up to it, spun the wheel once and see if it caught 8 pulses or more.
Thanks,
