Past few Weeks I was gathering lots of Info and now I would like to share what I've learnd and what I am planning:
Bottom-EndCrankshaft + Bearings from Diesel: 88mm Hub (16.6kg) Stock 13.2kg
Eagle Forget Conrods: 135mm (22mm pin, 540g) Stock 532g
Wiseco/Mahle Forget Pistons: 86mm (22mm pin, 320g) Stock 446g
Headgasket M44: 1.74mm
=> CR = 13.06:1 /1.85mm over deck/
Discplace: 2044.7cc = 8.6x8.6x8.8x3.14159 (511.17cc per Cyl)
Eagle Forget Conrods are the cheapest on the market: round 400$
Lucky for us the Mitsubishi Evo after 92' are 85mm with 22mm pin.
The Evolution 86mm Forget Pistons: round 520$, but Stock (good for more than 300 hp) they cost something like 75$ each.
About the Pistons: I've made some messurment and what I found:
88mm hub + M44 Piston + 140mm M44 Rod = 2.25mm over DeckM44 Pistons got 30.4mm Comp. Hi.
The Evo Pistons Comp. Hi. is however 34.7-35mm.
which means:
88mm hub + EVO Piston + 140mm M44 Rod = 6.85mm over Deck88mm hub + EVO Piston + 135mm Eagle Rod = 1.85mm over Deck=>
1.85mm = 10.7cc
M44 Chamber Volume = 33cc
M44 1.74mm Gasket = 10.1cc
Evo Pistons (9.3:1) = 10cc /there are 9.0:1 and 8.5:1 ... so lots of choices/
CR = 1 + {511.17/[(33+10.1+10)-10.7]} = 13.06:1
CR with 2.04 M44 Gasket = 12.57:1
I just don't know what would be safe as a size above deck, but I think a thicker gasket and little bit shaving the pistons would be enough. I am looking forward to at least 12:1 CR
----------------------------------------------------------------M44 Head35mm Intake Valve
31.5mm Exhaust Valve
Catcams
Reworked Head
Stiffer Springs (dbilas or Catcams)
Int Valve from S54 (E46 M3) /117mmX6mmX35mm/ reworked to the same length as M44 Valve.
Ex. Valve from Supertech
There are 2 Options for the Cams:
I. Catcams 283/284 (PartNr: 1301701) - used with O.E.M Parts
II. Catcams 312/304 (PartNr: 1301752) - used with Stiffer Springs and Solid Lifter (Pushrods)
As for the Stock M44 Head:
Beehive Valvesprings /37g/
Int. Valve 33mmX6mm /47g/
Ex. Valve 30.5mmX6mm /47g/
Hydr. Pushrod /45g/
Alone here everything is much lighter than the M42
So I would be glad to have a little discussion about the Camshafts. For how much RPMs is the Option 1 good (284/283 with O.E.M parts ... probably stiffer springs) and up which point does Option 2 make sence?
