Hi everyone. This is my first post....
I bought a 1991 318i back in December. I can't believe how much satisfaction this car has brought to me, especially considering it cost less than 10% of what my x3 cost! I bought it as an autocross car, but I've fallen in love with the car and now I'm thinking I might even fully restore it. I'm a little jealous seeing all the nice specimens in all of your signatures. I know I have a long way to go, but I'm in no hurry.
Let me make something clear before I pose my problem: prior to purchasing this car I had never even changed my own oil. But when I bought the car I also made it a point to start trying to figure out the mechanics of automobiles. I took the little garage that I have here at my complex and turned it into a workshop of sorts. Bought some tools, tiled the floor, added some better lighting, and now I have just about everything I need for simple to medium complexity projects.
OK onto the problem. I've run across a lot of leaks on this car. The first few were fuel related, and I'm afraid of gasoline getting everywhere so I took it into the shop. I've been trying to figure out why I'm leaking oil. It's not as obvious as I might have thought, and since I started trying to find the source of these leaks (I'm thinking there are various leaks because of the pattern on the floor) I've run across a more serious leak... coolant. I first noticed it on Sunday morning as I was getting ready to take the car to a friend of mine who was going to help me install new shocks and springs! Over the course of the day it got progressively worse, and by the time it was back in the garage and sat overnight I was looking at about a puddle around 12" across.
I looked all over the engine, and could not see where the leak was coming from. I can see green stuff on the "ledges" of the transmission, but nowhere above the upper manifold, and only on the driver side of the engine. I read some posts about the faulty profile gasket but I'm pretty sure with over 150K that has been taken care of, plus I can't see any coolant coming from anywhere near that area.
I decided to take a big jump into auto repair and followed some instructions on how to remove the intake manifold. It was really different on my car compared to the one I was reading, but I dumbly just started unscrewing things and although I have a huge mess of hoses now I think :eek: I'll be able to get it back together...
OK so after everything was out of the way I reached what I THINK is the bottom of the cooling system... a plastic pipe attached to the block. At this point I can tell that nothing is leaking from the hoses at the back of the engine (closest to the firewall), everything is bone dry. Nothing is leaking to/from the radiator either. All of the hoses along the system were clamped really tight too, so I don't think it is the connections themselves.
Here is the problem: nothing was broken/deteriorated/gashed. All of the hoses look fine! Well there was one problem, the plastic pipe, but only inside the engine where it connects at the "o" ring. When I removed it part of it was left behind in the hole, I had to scrape it all out with a screwdriver.
I can't tell for sure, and sure as hell don't have the expertise to rule anything out, but it seems like the leak could not have come from anywhere but this part of the cooling system.
Is it possible that these hoses or the plastic tube were leaking even though there is no visible damage (except for at the plastic pipe connection to the block)? Is the coolant under enough pressure to squeeze through non-visible imperfections? If I replace and re-tighten ALL of the coolant hoses and the plastic tube, can there somehow still be a leak that I can't see? I ask because I'd like to replace everything but since it looks like nothing is broken I'm afraid it won't do any good.
By the way, I WILL eventually fix the "mess under the intake" but for now I'm satisfied with returning everything to the way it was and then making that a project for the future, once I know that everything is working OK as it came.
Yikes, thanks for reading my life story, for any of you that are still reading, thanks in advance and I look forward to being a contributing member to the forum, not just an information leech!
Erick
