Author Topic: ecuconnections chips  (Read 9842 times)
ecuconnections
« on: January 17, 2010, 11:44:54 PM »
Summer 2010
Turbo & NA Tunes
E36 M42B18  ECU: 0261203282    SW: 595 (last 3 digits on stock chip label)
E36 M42B18  ECU: 0261203282    SW: 626 (last 3 digits on stock chip label)
Turbo base tune chip will cost $200+shiping and is good for 10psi + custom rev limit(36LB injectors, T3/T4 Hybrid turbo, Intercooled)
NA tune will be $42+shiping and will add 15-20hp + custom rev limit
More to come....
If you have a ecu you would like to have chipped please post the ECU number & chip SW number . I will update tune availability ASAP
« Last Edit: February 20, 2010, 11:58:04 PM by ecuconnections »
persianbmw
« Reply #1 on: January 19, 2010, 12:57:00 PM »
will these tunes be very conservative since u will never be touching the car.
0 261 200 990
three numbers circled 078
ecuconnections
« Reply #2 on: January 19, 2010, 01:12:36 PM »
Quote from: persianbmw;85142
0 261 200 990
I can only offer base tune for turbo so yes they are somewhat conservative. Nobody should run turbo setup without wideband and if you have one you can tell me where fuel can be added or minus to make the best power for your setup.  I will look into your ecu ASAP
ecuconnections
« Reply #3 on: January 19, 2010, 01:17:47 PM »
0 261 200 990
I cannot find a ori read out of your ecu. 078 is on the physical chip?
persianbmw
« Reply #4 on: January 19, 2010, 01:20:32 PM »
when you take the metal cover off that says bosch under it is the board and theres one elevated piece which i assume is the chip on that is a white sticker that has 666
ecuconnections
« Reply #5 on: January 19, 2010, 01:27:02 PM »
Quote from: persianbmw;85147
You can see the chip and label style in the above photo
persianbmw
« Reply #6 on: January 19, 2010, 01:30:35 PM »
the guy at miller performance said my numbers 990 but theres no software in their database if u give me and email adress i can forward you the picture because for one reason or another for forums not letting me upload it
ecuconnections
« Reply #7 on: January 19, 2010, 01:31:24 PM »
persianbmw
« Reply #8 on: January 19, 2010, 01:49:15 PM »
email sent
ecuconnections
« Reply #9 on: February 20, 2010, 11:36:08 AM »
ecuconnections
« Reply #10 on: February 20, 2010, 11:57:40 PM »
The details for the 10psi boost chip will be 36LB injectors, T3/T4 Hybrid turbo, Intercooled
dvmotorsports
« Reply #11 on: February 22, 2010, 04:24:46 PM »
You should consider doing the 175 chip from the M42B18 in the E30's.
ecuconnections
« Reply #12 on: February 22, 2010, 09:24:53 PM »
Quote from: dvmotorsports;88118
I can yes . if you can tell me the numbers on your physical stock chip I can get working on one . If you are uncomfortable with removing the stock chip you can send me your ecu and cover cost of shipping both ways.
OBD1 Cars with EWS I can write you a tune if you send me your ecu or stock chip and cover shiping costs both ways
Please PM or Email@  ecuconnection(A_T)rogers.com
Regards
Bear
4banger
« Reply #13 on: February 23, 2010, 01:00:37 AM »
Quote from: ecuconnections;88133
Regards
Bear
i can give you the number on the stock chip tomorow. ive got 4 of them laying in the top draw of my toolbox at the shop
:D:D[SIGPIC][/SIGPIC]
ecuconnections
« Reply #14 on: February 23, 2010, 02:52:01 AM »
Quote from: 4banger;88151
sounds good
