Author Topic: Bleed Brakes?  (Read 1895 times)
derek9702
Bleed Brakes?
« on: January 11, 2010, 11:40:30 AM »
I'm replacing a grommet on my master cylinder fluid reservoir, do I need to bleed the brakes after doing this?
I wouldn't think so, due to the fact that I'll just remove the fluid from the reservoir, remove the reservoir, change the grommet, put the reservoir back on, then refill.
Bleed Brakes?
« Reply #1 on: January 11, 2010, 11:50:02 AM »
Nope, as long as no air gets into the master cylinder, you'll be OK.  No bleeding necessary.  You might want to change or trim the clutch hose too, while you're at it.
