Author Topic: stomp test, 1215?  (Read 4550 times)
superj
stomp test, 1215?
« on: January 10, 2010, 12:28:16 PM »
getting ready to head out but thought i would throw this up.  i did the stomp and count test and i think it was reading 1-2-1-5 and hten it would hold for a second and repeat.  i am going to google what hte codes are but if someone happens to know,  that would be great
1982 bmw 320i
1991 bmw 318i mtech2, 4 door
2002 jeep liberty sport
stomp test, 1215?
« Reply #1 on: January 10, 2010, 12:29:44 PM »
1215 is an AFM problem.  Check the connector...mine was shorted with water...I pulled out the BMW resistor pack extension & tossed it.  Cleared up the code right away.
Might be a sticky flapper, or a bad temp sensor too.  There are testing directions in the ETM & Bentley IIRC.
« Last Edit: January 10, 2010, 12:31:55 PM by DesktopDave »
superj
stomp test, 1215?
« Reply #2 on: January 10, 2010, 09:38:28 PM »
don't know what it was.  it started running fine now.  the wife thinks it was the gas that was in it since this is just a weekend car (well,  was till the engine in her jeep went bye bye)
i pulled all the plugs for anything and sprayed them out with wd-40 and also ran with the icv unhooked for about a day.  it got rid of the hunting idle but raised it up to 1200.  once i noticed the car was running without bucking anymore,  i plugged hte icv back in and the car has been great ever since.
i think next time it happens,  i will try unhooking the battery for a while and see if it does it again and then checking the codes so i get it fresh
1982 bmw 320i
stomp test, 1215?
« Reply #3 on: January 11, 2010, 07:04:30 AM »
Might be that the WD40 cleaned the contacts or drove out the water.  Glad to hear your troubles are solved!
I use contact cleaner instead of WD40 though.  Less residue and better cleaning, even good for computers & other electronics.  You can get a spray can at Radio Shack for a few bucks.  Don't get too much on your hands, it has a mild acid to etch corrosion off copper, tin & gold.
superj
stomp test, 1215?
« Reply #4 on: January 14, 2010, 11:43:50 AM »
now that you say that,  i have a can from when i did my megasquirt build for my old 325i.
1982 bmw 320i
stomp test, 1215?
« Reply #5 on: January 14, 2010, 12:08:29 PM »
Do you still have the code for that?  I have a 2.2 unit that I was thinking of wiring up...on a 325i that I just bought!
superj
stomp test, 1215?
« Reply #6 on: January 15, 2010, 03:55:24 PM »
the maps for the megasquirt?  no,  i could never get it to run,  i'm not computer literate enough or something.  it bench tested perfect but when it came to running i couldn't get it figured out.
i got all my info from one of the guys on e30tech.com.  he sent me a map and helped with everything.  e30tech is the megasquirt for e30s headquarters.
i might have the proper tps though,  for the 325i.  i had a few real varible tps from other model bmws,  not the on/off like the 325i comes with
1982 bmw 320i
stomp test, 1215?
« Reply #7 on: January 15, 2010, 04:28:37 PM »
I heard that MS 2.2 couldn't run the BMW IAC without some special wiring or a daurghter card of some sort.  I've read some of the directions & wikis out there, seems pretty involved.  Eliminating the AFM is a big step, too bad the IAC cant go too.
Which BMWs have a variable?  The 325i seems to have a bad one anyway...just ran it today and it was doing the famous M20 wandering idle.
superj
stomp test, 1215?
« Reply #8 on: January 16, 2010, 01:22:37 PM »
you do have to either run a daughter card or no iac and just set the throttle screw out a bit for idle speed.
you can get anyone from an m30 3.5 that is newer then.......... i cannot remember.  i had one from an early 903 735,  one from a 90s 535 and one from something else.  they are hear somewhere
1982 bmw 320i
