Author Topic: Cranks but won't start  (Read 4569 times)
e30arm
« on: January 09, 2010, 06:34:21 PM »
Hello everyone!
I am a new and proud owner of E30 318.
I had this car for over a year now. The car was running fine, until alternator died.
The car was sitting in my garage for over 6 months, couple of days ago I installed new (reman) alternator.
Not it cranks but wont start, and I can't hear the fuel pump running, so I bought new fuel pump off ebay, and still the same problem.
Any ideas what could be wrong? Is there any relay or fuse for the fuel pump?
e30arm
« Reply #1 on: January 09, 2010, 08:04:02 PM »
plz somebody help
dj91318is
« Reply #2 on: January 09, 2010, 09:34:41 PM »
Hello e30arm - Wish I could be more specific and help you besides telling you to search on here. Look in the Engine and Drive line section you will fined all your answers. There is a lot of threads that has been written about this. Do you have a Service Manual?  GL
« Reply #3 on: January 09, 2010, 10:15:48 PM »
First do the stomp test to see if you have stored codes.  If you get a 1444, I'd figure it's the crank position sensor, fuel pump relay, or associated wiring.
Pull & test the fuel pump relay (it's mounted on a small 3-relay block under the firewall plastic).  It'll click if you put 12v on pins 85 & 86.  While it's out, short pins 30 & 87 on the socket with a bit of wire & see if that wakes up your pump.
Check the resistance of the crank position sensor.  Should be 'round 600 ohms.  The ECU/DME won't turn on the pump until the crank position sensor sends a signal.
e30arm
« Reply #4 on: January 10, 2010, 02:22:06 PM »
thanks for your responses.
I just did stomp test and came up with 1 1 2 1 code.
I am checking the relay now
e30arm
« Reply #5 on: January 10, 2010, 02:48:40 PM »
when I did this, the pump turned on, and didnt turn off is it normal?
 i tried to start it but it didnt
e30arm
« Reply #6 on: January 10, 2010, 02:59:39 PM »
I found the problem.
When i replaced the valve cover gasket, i didnt put the spark plug wires in order.
Thanks to this thread http://m42club.com/forums/showthread.php?t=10414
carlos318is
« Reply #7 on: January 10, 2010, 03:05:57 PM »
Glad you got it sorted mate
e30arm
« Reply #8 on: January 10, 2010, 03:21:57 PM »
thanks to all of you :D
« Reply #9 on: January 10, 2010, 03:46:48 PM »
Quote from: e30arm;84348
Glad you got her back on the road.  FYI the pump will stay on if you do this test.
