Author Topic: What is this thing HELP - pigtail on AFM  (Read 2145 times)
dcroteau
« on: January 08, 2010, 08:15:25 AM »
My 91 318 with of course the M42 engine starting dying on me, luck was with me as I was just about pulling into my garage. An examination of the check engine fault code indicated the the AFM.
Looking for the cause I was suprised to find that in between the factory connector and the AFM there was an extension . Not pin for pin this thing looks factory and has male/female round connectors. But when I peeled back the rubber boot it has about a 3/4" square black encapsulated juntion where some alteration of the wires going from point a-b occurs. One of the pins at the AFM becomes a no connect and there is now some measured resistance betweeen two other. The cause of my problem was a broken wire in the factory harness/connector which I repaired.
The car runs fine again and the check engine light is off. I reconnected the pigtail extenision since it has been there all along. But what the heck is this it. I'm thinking maybe a factory upgrade or it's some kind of aftermarket item.
Can anyone shed any light on this thanks
nicknikolovski
« Reply #1 on: January 08, 2010, 04:27:47 PM »
Could you post a picture please?
« Reply #2 on: January 08, 2010, 04:35:55 PM »
http://www.m42club.com/forums/showthread.php?t=10552
BMW OEM recall fix for poor driveability.  Not necessary, but it might make the car smoother in action.  Being as smooth as I am, I had little need for it.
