Author Topic: E30 318is battery problems  (Read 2828 times)
HHH_SSS
« on: January 07, 2010, 11:34:47 PM »
Ok so winter started and I parked my e30 in the garage. I make sure I dont let it sit too long, I make sure I start and drive it every once in a awhile. Now ever since it started getting really cold up here in mn I come to try and start the car and the battery is dead. That was no big deal it was something I excpected because it was so cold and i havent started it for a while. So I jump start it and it runs fine. I made sure to drive it around too. The problem is now everytime i try and start it up either the battery is dead or most of the time the lights are VERY dim and the battery doesnt have enough juice to start (cranks a little bit the first try but very weak). This happens every time i try and start the car now.If i turn off the car and start it again right away then the car has enough juice to start but if i leave it off longer than like 10 15 mins I try and start the car and the lights will be REALLY dim and wont have enough juice to start. I know this is probably a simple answer but Im a noob so if anyone knows what it could be: Alternator, battery itself... I would realy appreaciate the help. THANKS!
3bvert
« Reply #1 on: January 07, 2010, 11:47:17 PM »
battery
« Reply #2 on: January 08, 2010, 06:52:51 AM »
Battery.  You can take it to an auto parts store for a free test.  You could get a multimeter to tell you pretty much the same thing.
It's just metal & acid...in six 2 volt chambers called "cells."  One or more of these cells are eroded & is now shorted out, I'll bet you have only 8-10 volts left in that battery...not enough to crank the engine.
Happily, they're easy to change out & cheap to troubleshoot.
