Author Topic: Crankshaft specs?  (Read 1909 times)
KenC
Crankshaft specs?
« on: January 04, 2010, 05:32:31 PM »
I'm going to yank my crankshaft soon. How do I check the bearing surfaces to make sure they're within their tolerances and don't need oversized bearings? I'm assuming just with calipers, bu I just want to get details and numbers.
BlueBMW
Crankshaft specs?
« Reply #1 on: January 04, 2010, 08:45:35 PM »
In this post I put up some size specifications for an M42B18 (it was for a 95 318is)  If you want me to look up for a different car just let me know.
http://www.m42club.com/forums/showthread.php?t=10417
Although I've never done much engine building myself, when I built plastic injection molds I usually measured with micrometers for outside dimensions and a depth mic with a gauge pin for inside surfaces.  I'd think any sort of micrometer would be more accurate than calipers (though you can get pretty close with a good set of calipers)
« Last Edit: January 04, 2010, 08:48:08 PM by BlueBMW »
