Author Topic: Fuel pressure???  (Read 2539 times)
kidnafarious
Fuel pressure???
« on: December 23, 2009, 05:19:31 PM »
what should my fuel pressure be???
i think i need a fuel pressure regulator
is it worth getting an ajustable fpr???
if so, would there be any noticeable gains from upping the fuel pressure???
i dont kno if this matters but.... i did the mess under the intake mod, mustang injectors, throttle heater plate delete.... and it has a k&n cone filter with heatsheild...
thanks for any help/opinions
Fuel pressure???
« Reply #1 on: December 23, 2009, 07:09:29 PM »
Is it running badly?  Low fuel mileage?
1991 E30 M42
Fuel pressure???
« Reply #2 on: December 23, 2009, 07:29:05 PM »
Your fuel pressure should be 3 bar which is about 43 psi, as for and adjustable I do not think you would see any gains on a stock engine or a stock ecu that has adaptive learning.
kidnafarious
Fuel pressure???
« Reply #3 on: December 24, 2009, 03:55:02 PM »
its getting crappy fuel mileage....it also kinda stumbles under three thousand rpm...
thanks for the input guys... much appreciated
