Author Topic: E36 M42 engine rebuild factory specs?  (Read 12639 times)
wannam42
« on: December 21, 2009, 08:54:41 AM »
I'm planning to do a full rebuild of an M42 from an E36. Does anyone have a list of specs / tolerances for the machine shop to follow?
The E36 Bentley manual lists some but it's for the head and it may not even be complete. I don't have the Haynes.
I've read on this forum that the E36 and E30 M42s do not share the same set of piston rings. I'm not sure what else is different. :confused:
Can anyone help me?
longtallsally
« Reply #1 on: December 25, 2009, 06:45:56 PM »
Ooooh.  I wanna know some of this too as I'd eventually like to rebuild my engine, or swap in one that I've rebuilt.
BlueBMW
« Reply #2 on: December 26, 2009, 09:41:52 AM »
Here's what I've gathered from the technical data I have access to.  This is for an E36 318is coupe with an M42b18 (US Spec of course)  Hope this helps
wannam42
« Reply #3 on: December 30, 2009, 11:20:24 PM »
Many thanks BlueBMW! I can't understand half of it though. :o
What does the +0.014 mean in the bore dimensions?
Did I read it right that valve guides aren't replaceable for the E36 M42?
The conrod bearing journals have a +0.009 and a +0.025 notation. What does this mean?
The piston-to-wall clearance is 0.01 - 0.04mm? That's 0.00039 inches! So what does the 0.15mm max wear clearance between piston and cylinder mean? :confused:
dwtaylorpdx
« Reply #4 on: December 31, 2009, 12:37:21 AM »
They are drilled in place, however a good engine builder can bore them out and put sil-bronze ones in.
Dave
BlueBMW
« Reply #5 on: December 31, 2009, 06:51:39 AM »
From what I can tell those + numbers are tolerances meaning it could be up to that much larger than spec.  I haven't done much engine building so I cant say for sure.  Those are just what I could find in technical documentation.
wannam42
« Reply #6 on: January 01, 2010, 11:03:56 PM »
No worries, BlueBMW. :)
Interestingly, this is more complete and quite similar to the tech info that cecotto gave in this thread: http://m42club.com/forums/showthread.php?t=1985
It looks like the E36 and E30 clearances are the same.
wannam42
« Reply #7 on: January 01, 2010, 11:10:58 PM »
I almost forgot. Thanks for the info as well, Dave. :) I'll be sure to ask the machine shop to do this. Not sure if this is really necessary though. What do you think?
