Author Topic: cams  (Read 3209 times)
M3kos
cams
« on: August 10, 2006, 09:13:45 PM »
new here and posted what i'm after on the link at the end
i need to know about cams
who's used what, duration and lift and power gains
regards
kos
http://www.m42club.com/forums/showthread.php?p=9559#post9559
Febi Guibo
  • m42 reporter
cams
« Reply #1 on: August 10, 2006, 10:15:01 PM »
I have (around*) a 282 intake, 272 exhaust, with a ton of overlap (don't quote me on this)...
i have yet to dyno the car, but really, butt-dyno wise... the cams shift the power more than increase it (net-net).
the real deal is to combine the camming with a raised rev limit to squeeze more power out of each gear change  ...for our 4-cyl cars, that's kind of the trick.
Support M42club.com !!
M3kos
cams
« Reply #2 on: August 11, 2006, 08:51:18 AM »
ok, that i follow, more power but at higher RPM, so that leads me to ask what is the safe RPM limit on a stock M42 bottom end, mines currently set at 6950 rpm
silverblades181
cams
« Reply #3 on: August 11, 2006, 04:14:46 PM »
The MarkD chip gives you a 7200 rpm limit with stock interns. I wouldn't rev higher than that with a stock engine
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
2002maniac
cams
« Reply #4 on: August 11, 2006, 04:51:16 PM »
Quote from: silverblades181
Actually it is 7100RPM
The bottom end is not the weak link in the M42.  At higher Rpm's you could experience valve float which could mean valve/piston contact.
I have Reground cams from Delta Camshaft of Tacoma WA.  I lost the spec sheet, but I like them.  Power from 4000-7100 is nice.
Jtuner
cams
« Reply #5 on: August 12, 2006, 02:43:39 AM »
I was thinking about the same thing this fall when I get my school money.. I would like to build a head for my car, and make it so I can bolt on a turbo in the near future.. Any suggestions?
Euro Nation
cams
« Reply #6 on: August 12, 2006, 03:04:22 AM »
called Delta today. They had no idea what I was talking about with the M42. "One step higher than stock" was all they could tell me. No numbers.
-Aaron
\'91 318i - Dead and gone
http://www.euronationvw.com
I own VWs... lots of them.
