Author Topic: Post your suspension setup  (Read 29098 times)
rjcaptsean
« Reply #45 on: January 28, 2011, 01:40:42 PM »
The only Vert in here has an M3 setup.  Just talked to H&R and they say that the reg 318is sports will sag lower in the back and look bad.  What are people using in the verts for lowering?
JakeP
« Reply #46 on: February 02, 2011, 07:45:42 PM »
Why don't we try using this format and include part numbers/spring rates if you have them:
Year:
Model:
Wheels (##x## et:##):
Tires:
Spacers (if any):
Front Springs:
Front Shocks:
Front Sway Bar:
Other Front Suspension Mods:
Rear springs:
Rear Shocks:
Rear Sway Bar:
Other Rear Suspension Mods:
Pictures:
bwawuz02
« Reply #47 on: February 07, 2011, 03:07:28 PM »
This weekend I installed...
New control arms and M3 CABs
H&R 29664 springs
Bilstein Sports
E90 drop hats
I'm pretty pleased with the looks and very pleased with the comfortable ride, yet much improved handling.
Next weekend...
Z3 rack swap :D
JakeP
« Reply #48 on: February 09, 2011, 06:04:18 PM »
Quote from: bwawuz02;101232
H&R 29664 springs
Bilstein Sports
E90 drop hats
Next weekend...
Z3 rack swap :D
And yet you don't post pictures or measurements.... :confused:
bwawuz02
« Reply #49 on: February 10, 2011, 08:01:00 PM »
i will soon, when it's all done. I gotta finish up and swap in the rear subframe i'm building (refreshed 3.91 LSD w/MZ3 bushing, AKG 80A subframe bushings/75D TA bushings, weld-in camber/toe kit, re-inforced TAs, and new rear wheel bearings... just waiting on the bushings/bearings to get here so I can put it all together) Still waiting for my backordered General Exclaim UHP tires to come so i can mount my kosei K1s that are almost refinished.
mr.vang
« Reply #50 on: February 11, 2011, 01:06:15 AM »
cosmo coil, cosmo adjustable top mount, sport billy
fs: air bag model knee panel, bmw tools, ects
bwawuz02
« Reply #51 on: March 13, 2011, 12:49:53 PM »
the rear end isn't finished yet, but I can email you some teasers. She's no beauty queen, but my fav E30 to drive having own 2 325is in the past.
95 318ti M42 is on the stand with M44 crank inside. Engine will be at Rebello Racing later this month getting the bottom end put together/balanced, just waiting on pistons to show up.
« Last Edit: March 13, 2011, 12:52:17 PM by bwawuz02 »
Nick_318is
  • -Receive: 11
« Reply #52 on: March 13, 2011, 03:28:58 PM »
I'm running the following:
Dinan Springs
Bilstien Sports
M3 CAB
Ireland Engineering 22/19 adjustable bars
The stance before and after:
bwawuz02
« Reply #53 on: May 22, 2011, 03:10:14 PM »
H&R 29664 / Bill Sports
GC Touring plates
10mm rear spring pads
ST Sways
Still haven't had time to swap my rebuilt rear-end in, or put on the RX-7 brakes.
White lower valence will be here on Tuesday. Then I'll be ordering an IS lip/skirts and hitting the body shop.
Kosei K1 15x7 et27 205/50/15 Dunlops
« Last Edit: May 22, 2011, 03:16:02 PM by bwawuz02 »
