Author Topic: Engine compartment detailing.  (Read 4740 times)
« on: August 10, 2006, 01:09:53 PM »
I want a nice looking engine compartment. What is the hot tip on the following items:
1) Removing cosmoline
2) getting the valve cover and intake looking good
3) treating the plastic pieces to look good
4) cleaning and maintaining
Pics are helpful.
Febi Guibo
  • m42 reporter
« Reply #1 on: August 10, 2006, 01:28:32 PM »
for hoses and plastic parts, I highly recommend an aerosol non-yellowing silicone spray... it works GREAT, seriously.
Support M42club.com !!
FL318is
Engine detail to date
« Reply #2 on: August 10, 2006, 02:15:22 PM »
Since I have been working on mine I have started the engine detailing.
For the intake and valve cover I used the 500 degree engine paint.  I used the aracite grey just because it was handy in the shop.  Later I will dremel the ribs and emblems.  Much later, I will probably use a different color.  When I have it home I will take some pics.  The engine does look a whole lot better.
The only thing I have found to date for cosmoline removal is the liquid used in the parts cleaner bath.  I might try a little of that on the towers and wells.
M42boy
« Reply #3 on: August 10, 2006, 04:53:15 PM »
Quote from: Febi Guibo
For hoses, try Wurth Rubber Protectant (aerosal).
My advice... live with the Cosmo...   It may not look hot, but it IS a protective coating.  ;)
Febi Guibo
  • m42 reporter
« Reply #4 on: August 10, 2006, 10:21:55 PM »
yeah, the cosmo protects your engine from looking good  :) !!
speaking of wurth... their 'Citrus Based Solvent Degreaser' comes recommended for cosmoline removal...
StreetSpec_iS
« Reply #5 on: August 10, 2006, 11:22:51 PM »
^ kenoath, citrus based product is what i have found to work best.
i think i used a citrus based overn cleaner and steel wool.
Berlin
« Reply #6 on: August 11, 2006, 03:00:52 AM »
castrol super clean.... for the generally drity areas, works like a charm
and i found this other thing Walter X-force... cleans plastic and protects it but its best hidden benefit is brake dust removal... makes your wheels so clean it hurts
Tonyb
« Reply #7 on: August 12, 2006, 02:22:08 AM »
I used Tal-StripII aircraft coating remover. It took everything off right down to the original finish. I bought it at a local auto parts store for 24.00$ a gal.
