Author Topic: '93M42 to '98M44 swap. List of requirements  (Read 2407 times)
dinu.negrean
« on: November 28, 2009, 07:24:07 AM »
Hey guys
The time has come to make the swap that i have been waiting for, I have found a car that the owner wants to break apart, and I need a list of everything that I need in order to make the swap. Tuesday I will make a nice roadtrip with my friend for 1000km to go get the engine + everything else that I need. So i need you you to help me put together a list of everything that is needed. I'll start with the elements that I know, and any of you who have knowledge of this matter can feel free to continue my list.
1. Complete engine.
2. Wiring harness complete
3. ECU
4. MAF sensor
I have read something about the key of the car, is it right? I will need the key for the immobiliser? if so, what else is it needed to work? Do i have to also take the starting hub? If it's only the chip I will put my keyblade into that one. From here on it's on you guys, please help so I won;t make this trip useless.
One other thing, I have the getrag 250 on my car with twin mass flywheel cluctch brand new. Can I fit it on the m44?
Thanks,
Dinu
dinu.negrean
« Reply #1 on: November 28, 2009, 07:24:44 AM »
I have been reading many opinions but no one can really say "Yes, I have done it and it goes like this".
Now I'm thinking..
IF: I use only the M44 engine, wiring and ECU I will still have the ignition EWS problem, which I don't know how to solve. Can that stuff be cut off or by-passed in some way? What do I have to also break from the M44 to solve the EWS problem?
OR: Is it possible to use the M44 engine with M42intake, M42Wires and M42ECU?
Some help would be greatly apreciated as I am a bit short of time.
Regards,
Dinu
Eric Happy Meal
« Reply #2 on: November 28, 2009, 02:00:34 PM »
if you want to do the swap correctly it takes a bit of work.  if you just want to get the motor running in your car all you need to do is take everything off your M42 and swap it onto the M44.
kote_alex
« Reply #3 on: December 02, 2009, 02:18:08 PM »
Te bate gandu la un M44 ?
Unde ti-ai gasit ? :D
