aluminum flywheel
Author Topic: aluminum flywheel  (Read 4846 times)
gravyface
aluminum flywheel
« on: November 23, 2009, 09:22:34 PM »
Anyone replace their stock flywheel with an m42 aluminum flywheel on their 318is?  Looking for parts sources, opinions before and after, etc.
Bmex318i
aluminum flywheel
« Reply #1 on: November 23, 2009, 10:46:54 PM »
Im running a 12lbs from an e36 m42.... from HPF. Works fine the only bad thing it drops speed while shifting, but works good..
Andy_Casey
aluminum flywheel
« Reply #2 on: November 24, 2009, 03:47:56 AM »
Road or track use? For road use you're better off with a lightened SM wheel IMO. Are you runnign SM or DM FW at the mo? Fitting a SM wheel to my S2 made a really nice difference, a mate has been running a lightened SM on his IS for a while and it's really nice.
Cheers\'en
AndyC
1990 BMW 318is - 160bhp - daily transport
1994 Audi S2 Coupe - 300bhp - reformed luxo-barge
gtatbrissy
aluminum flywheel
« Reply #3 on: November 24, 2009, 04:47:44 AM »
Andy_Casey
aluminum flywheel
« Reply #4 on: November 24, 2009, 07:04:39 AM »
LOL @ 'that's dangerous' post. Seen many flywheels like that, thing to do is get it done professionally and then balanced along with the clutch assembly, better for revs, better for smoothness.
Cheers\'en
AndyC
gravyface
aluminum flywheel
« Reply #5 on: November 24, 2009, 08:44:41 AM »
Quote from: Andy_Casey;82004
Street/autox, and car's my daily.  I'm thinking the m20 flywheel conversion sounds like a happy medium.
aluminum flywheel
« Reply #6 on: November 24, 2009, 11:39:02 AM »
I recommend the M20 flywheel conversion (it has to be from the post 1988 "i" motor).
http://bmw.e30tuner.com/my318is_pic_rebuild6.php
As I discovered, you actually only save 5lbs total because the M20 pressure plate is heavier.  Still, that's a 12% reduction in mass (and the M20 flywheel has less of it concentrated around the outside diameter, which also helps).  From what I understand, you can have the M20 flywheel machined down to ~11lbs from its original 19lbs.  It is just hard to find a reputable shop that is willing to do it!
« Last Edit: November 24, 2009, 11:42:48 AM by bmwman91 »
1991 E30 M42
aluminum flywheel
« Reply #7 on: November 24, 2009, 02:18:45 PM »
I have a 9lb m20 flywheel from metric mechanic. They also machine it to accept the m42 starter ring so you do not have to change the bendix on the starter
fiftytakedowns
aluminum flywheel
« Reply #8 on: November 24, 2009, 02:33:20 PM »
Quote from: Bmex318i;82003
Im wondering if the aluminum flyhweels have the little pin thing for TDC if you want to do a timing chain job.
gtatbrissy
aluminum flywheel
« Reply #9 on: November 25, 2009, 03:29:52 AM »
Quote from: fiftytakedowns;82028
nah i would be on the crank, mine didnt have any marks for tdc
Andy_Casey
aluminum flywheel
« Reply #10 on: November 25, 2009, 05:51:24 AM »
I would expect to get a FW lightened over here at a decent machine shop for £100. MM are offering it for $350 but 11lbs is quite light!
http://www.metricmechanic.com/prices/pricing-clutches-and-flywheels.php
Why not source a SM flywheel from this side of the pond, got to be a few about here and certainyl in germany on ebay.de... there are 5 secondhand ones on there for between 30 and 40 euros from the same place. Maybe he'll send the lot out to the states, never can tell on ebay.de.
http://shop.ebay.de/i.html?_nkw=m42+schwungscheibe&_sacat=0&_trksid=p3286.m270.l1313&_odkw=e30+schwungscheibe&_osacat=0
« Last Edit: November 25, 2009, 06:02:55 AM by Andy_Casey »
Cheers\'en
AndyC
