Author Topic: Rear Camber adjustment  (Read 3263 times)
Blip Bavarian
« on: November 03, 2009, 09:52:21 AM »
Hey guys.  So i guess there is no way to adj rear camber or toe with the stock setup, right?
Isnt there something that you can add to your rear susp to make it adjustabe.  Can you guys point me in the right direction...
Thanks
Matt
monty23psk
  • -Receive: 17
« Reply #1 on: November 03, 2009, 11:53:32 AM »
You really only have 2 options unless you build a custom rear end. You get trailing arm bushings that are eccentric which give you 1-2 degree each way or you slot the trailing arm mounting points which allow even move adjusment plus believe it gives you for both camber and toe while the other does not.
HMS_Tim
HMS_Tim
« Reply #3 on: November 09, 2009, 10:38:50 AM »
son of a b..
the link doesn;t work at all
so go to bimmerworld.com
in the search field type in
Rear Camber/Toe Adjustment Kit - E30, Z3, 318ti
it'll come up.  it took me a bit of time to setup and weld, but the overall final product offers a ton of rear adjustment.
