So I just replaced my head gasket, and after getting everything back together the car won't start. The starter engages and turns the engine until one of two things happens: either the engine and starter stop instantly, or the engine stops and the started spins for a little. I've had the battery in the car the whole time, so weak battery isn't entirely impossible, but it seems strong. Also, my crank position sensor wire is a little frayed, but worked fine before i pulled everything apart. I'm fairly sure I got the timing right, but that seems like the most likely culprit. Maybe I got the cam gears switched when i put them back on... but they looked identical, and the arrows were pointing up.
Any guesses welcome... I gotta get this running so I can get out of Buffalo before the cold weather hits.
